FlexCAN Receive model in Model Based Design ToolBox for S32k
李风heart
Hi:
   I 'm using FlexCAN Model in MBD ToolBox, I change the example model flexcan_s32k14 like this: pastedImage_219.png
pastedImage_225.pngI send a Message (ID:0X3FE) to the S32k144 EVB. It send the message (ID:0x3FB) back.The question is why the data in message EVB sends out(ID:0x3FB) always the last Data it receievd, how to make the data be zeros or a default value while I didn't send Message for longer.
My MBDToolBox Version is V3.0.
constantinrazva
Hello 李风heart‌,
Can you share your model? Or just the part with CAN that is of interest? I'd like to take a look and get a better understanding of what you are doing versus what you want to achieve and looking into the model would help.
Kind regards,
Razvan.
李风heart
Hi constantinrazvan.chivu,
   This is my demo model, I just want to make the data in Message '0X3FB' be zeros while I didnot Send '0x3FE' to S32K board.
   By the way, my MBDToolBox version is V3.0.
constantinrazva
Hello 李风heart‌,
Can you check you have sent the correct model? I'm having trouble opening it - I've tried in MATLAB R2017b, 18a, 19a, and the error is the same.
It would be good if you could export the .slx to .mdl format.
Kind regards,
Razvan.
