how to use usdhc3 for Android auto_Ga_2.1.0 xen version
wuguangnan110
I want to use usdhc3 for wifi sdio,i try to change dom0 dts to passthrough  usdhc3 for domU(android),as follow :
arch/arm64/boot/dts/freescale/fsl-imx8qm-mek-domu.dts:
and the log is :
libxl: error: libxl_create.c:1345:domcreate_launch_dm: Domain 3:failed give domain access to iomem range 5b220-5b220: Operation not permitted
can you help me please!
cp2
has there any documentation about using wifi in xen arrived in the meantime?
Peng_Fan
Please add a node including sdhc3 lpcg iomem, and mark passthrough, no need smmu entry for it. Check how lpuart passthrough in imx8qm-mek-dom0.dts.
Kernel & Virtualization Engineer
jinchen1227
Same question, any one help?
diegoadrian
Unfortunately, the i.MX8QM is still in preproduction and we do not have any preliminary documentation about the product. I recommend you to go with your DFAE. He could help you with this problem.
I apologize for the inconveniences this could give you.
Diego.
