What is the maximum Capacity of EMMC, the LPC1788 support
liammcart
What is the maximum capacity of memory card that LPC1788 will support?
Alexis_A
Hi Liam,
This LPC has 256 Megabytes of static memory support and 1GB of Dynamic Memory. You can check this in the following table.
Alexis Andalon
liammcart
Hi Alexis,
Thanks for your response.
Sorry I meant EMMC not SDRAM.
Do you know the max capacity of EMMC the LPC1788 will support.
Thanks, Liam
Alexis_A
Hi Liam,
There is no limit from a hardware point of view.
Up to 32 GByte, you will get SDHC cards with FAT32 file system, over 32 GByte, the SDXC cards will have exFAT file system.
Alexis Andalon
