Hi Arunkumar
i.MX6 uses otg port in device mode, mfg tool usage is described in presentation
thanks for the replay.
In my application i need to use the OTG to transfer data to the USB host connected imx.
kindly share if any document available
one can look at usb unit tests
doc\mxc_usb_test\test - imx-test - i.MX Driver Test Application Software
