Where can I get the LTIB to compile kernel 4.1.15 for imx6sololite board? thanks.
Hello Kuoron,
LTIB is no longer supported. Yocto is now being used as a means of distribution and customization of the i.MX BSP images. You can find instructions on how to setup Yocto on the i.MX Yocto User’s Guide which is part of the 4.1.15 BSP Documentation Bundle on the link below (please note you may need to login to download this file).
https://www.nxp.com/webapp/Download?colCode=L4.1.15_2.1.0_LINUX_DOCS
I hope this helps,
