imx8mm-evk add a new partition
mikezhao
imx8mm-evk boot from emmc , How to add a new partition ?  and How to modify the size of the partition ?
Hi zhao
one can look at uuu documentation on GitHub - NXPmicro/mfgtools: Freescale/NXP I.MX Chip image deploy tools.
https://github.com/NXPmicro/mfgtools/releases/download/uuu_1.2.0/UUU.pdf
for android one can look at its Android User's Guide documentation on
i.MX Software | NXP
achyut_hegde
Hello igorpadykov @lizhi
I was trying to flash Android 10 images that I built for imx8mq EVK.
I got the same error as mentioned by li zhi. And there is no information about fixing it anywhere.
But when I checked in fastboot devices, I could see a new entry.
I just did 'fastboot reboot' in the same command prompt.
After that run the command ./uuu_imx_android_flash.sh -f imx8mm -a -e -u trusty
Error was fixed and emmc was successfully flashed.
litchi1983
       I have downloaded the UUU.pdf and msgtools, but can not found that how to add a new partition. Could you please give more advice ?  I am developing with imx8mq, on Android P.
