RTC Operation in power down mode in LPC546xx Microcontroller
prasannanaik
   I have a query regarding operation of RTC in LPC546. I want to know whether the RTC counter register (COUNT) will keep on updating or not in device power down mode (i.e no VDD only VBAT). The datasheet mentions that the . RTC module and the oscillator that drives it, runs directly from the device power pins. Does this means that the RTC counter won't be updated in device power down mode(i.e when only Vbat is present).
I have attached the sceenshot of the datasheet for reference.
Thanks and best regards,
Prasanna
xiangjun_rong
Hi, Prasanna,
You are right, the RTC counter register (COUNT) will keep on updating in device power down mode (i.e no VDD only VBAT).
XiangJun Rong
xiangjun_rong
Hi, Prasanna,
XiangJun Rong
prasannanaik
Hi xiangjun.rong‌,
   Thanks for your help.
    I verified the same on LPC546xx development board OM30192.
Prasanna
