uBLOX support?
uBLOX support?
mspenard603
Hi All,
 Is there any example code to integrate a uBLOX (e.g., a NINA-W31 with its UART interface) with iMXRT and LWIP etc.?
jeremyzhou
Hi Mike Spenard,
the opportunity to serve you.
There's no example code about the uBLOX wifi module in the i.MX RT's SDK library, however, in the SDK library, it contains the Lwip code demos.
TIC
