Does PN5180 support writing MAX66242 tag?Have you done any actual verification?
Dear 光明 李, I see that the tag you mention is ISO 15693 so you should be able to use the commands in the reader library since there is some APIs for ISO15693, since this is not an NXP products is hard for me to tell or advice on this. my recommendation is that you check our reader library and check the commands .
Jonathan
