MCAL EXAMPLE ERROR
MCAL EXAMPLE ERROR
15359283122
Hi, everyone,when I use EB tresos24.0.0 import exp mcal example(C:\NXP\AUTOSAR\MPC574XG_MCAL4_0_RTM_1_0_5\MPC574XG_MCAL4_0_RTM_1_0_5_Sample_Application) and generate code,it report err.error.PNG
How can i fix the problem? Thanks a lot.
frantisekdobes
Please use Tresos version 14.2.1. The MPC574XG_MCAL4_0_RTM_1_0_5 release was tested with Tresos 14.2.1 so this version of Tresos shall be used.
In general the version of Tresos supported by a specific MCAL release can be found in MCAL release notes (for example for 1.0.5 in  c:\NXP\AUTOSAR\MPC574XG_MCAL4_0_RTM_1_0_5\MPC574XG_MCAL4_0_RTM_1_0_5_ReleaseNotes.pdf).
15359283122
Thanks. I use the MPC574XG_MCAL4_3_RTM_1_0_0.exe later.and it can generate code except IntegrationFramework module,it reports has no license for module IntegrationFramework_TS_T2D35M10I0R0.Why? How can I to request the license for module IntegrationFramework?Thanks a lot.In.PNG
frantisekdobes
The described issue with IntegrationFramework is fixed in MPC574XG_MCAL4_3_RTM_HF3_1_0_0.
15359283122
Thanks a lot.It(MPC574XG_MCAL4_3_RTM_HF3_1_0_0) can generate code without error.
