LPC11C14 - boot_jump() , Operand syntax error
yansinli
My code :
void boot_jump(uint32_t address)  /* Jump to user app form bootloader */
    __ASM("LDR SP, [R0]");      //Load new stack pointer address
    __ASM("LDR PC, [R0, #4]");  //Load new program counter address
err log :
Error[Og006]: Error in inline assembly: "Error[401]: Operand syntax error" ,
Device  : NXP LPC11C14FBD48_301
IAR IDE:
IAR Embedded Workbench for ARM 7.40.5.9739
IAR Embedded Workbench common components 7.2.7.3905
jeremyzhou
Hi yansin lee,
the opportunity to serve you.
To provide the fastest possible support, I'd highly recommend you to refer to the AN11772: LPC11Cxx CAN secondary bootloader which guide you how to jump to APP appropriately.
TIC
jeremyzhou
Hi yansin lee,
TIC
yansinli
very help answer~~ fix my question~~ thank you
