Reset Value Issue of AIPS of MPC5746R
qm1013
hello, I can't find the reset value of the Peripheral Bridge (AIPS-Lite) about the register definition .
MPC5746R devices.
where could I find the AIPS chip-specific informations ?
davidtosenovjan
Hi, it is stated in the first section of module description
qm1013
Also about the AIPS(Peripheral Bridge), I am confused about the supervisor privilege level on AIPS_PACRn register.
Marked in red , is it means that if SPI is set,the master need supervisor access attribute and MPRx[MPLn] set
I know how to configure the MPRx[MPLn] bit , but how to configure the supervisor access attribute for the specified master?
davidtosenovjan
If the particular master is the core, then its supervisor/user is given by MSR[PR]. Other masters are treated as supervisor.
