Hi Team,
We going to design our custom board using iMX8MQ.
As there is Micron's LPDDR4 used on EVK board. So, can we use 32Gb(4GB) Samsung LPDDR4 part number "K4FBE3D4HM-GFCL" on our custom board?
Is there any known issue or risk if I use this part?
Please provide a solution to this topic as soon as possible because I require it's solution very urgent.
Also, I have attached the Samsung LPDDR4 datasheet for reference.
Please also suggest the other alternative 4GB LPDDR4 parts which can I use with the iMX8MQ processors.
Thanks & regards,
Nirmal
Yes, you can use the LPDDR4 part you've specified without any issue.
There are no "preferred" memory parts, all JEDEC-compliant ones can be used.
Artur
Hello Artur,
What are the modifications we need to do in U-Boot OR Kernel for using different LPDDR4 Memory?
Thanks & Regards,
Kailas
