Verify Error
Verify Error
myna
Hello. S32K Team.
Now, I use s32k118_EVB.
But When I debug by using Trace32(Lauterbach), Sometimes Verify Error has occurred.
I don't know why 'verify Error' has occurred. Elf file is also generated well.
Could you tell me that reason for occurring Error and how to avoid error?
Please check attached file.
Thank you.
MinYeop
danielmartynek
It says that the .elf file can't be found.
Is the source path to the file correct?
BR, Daniel
