PEMicro configuration for MPC5748G
tobiasmrowietz
We are using the PEMicro Multilink FX for flashing and debugging our MPC5748G and encountered few issues so far.
Could you maybe help us with setting up a correct configuration here?
  • The debugger takes a lot of time to step over instructions to the point where the program is suspended with no message in console.
  • It takes a lot of time to flash the MCU at random iterations (gets stuck at 97% for a few minutes).
  • When going over some instructions the session is terminated with the following message in console :
Remote communication error.  Target disconnected.: No error.
martin_kovar
could you please tell me, which version of S32DS you use?
I recommend to use S32DS 2017.R1 with update 10, please see the link below.
https://community.nxp.com/docs/DOC-343018
The settings you shared looks correct. Do you use your own design board or NXP evaluation board?
Please let me know.
Martin
