KE1xF:
请问如何使用CAN 下载bootloader程序,需要特定的CAN工具吗?
How to use CAN to download bootloader program, need specific CAN tools?
Dear 孙雪 孙,
The KE1xF MCU counts with a ROM bootloader called MCUBoot, this bootloader is capable to use the CAN protocol to update the flash content. In the following link you can check the reference manual of the MCUBoot:
In the chapter 6.7 FlexCAN Peripheral you can find more information about this. You don't need specific CAN tools, only a host that can comunicate at 1 MHz.
I hope this helps you.
Alexis Andalon
