S32K144_ADC_DMA_using_processor_expert
harish_g2
Hi All,
We are using S32K144 chip and using s32 design studio with S32K144_SDK support.
Can someone tell me how to configure single channel ADC  DMA using processor expert?
We have seen an example for ADC over DMA directly but I wanted to configure using processor expert.
Requirement:
1. How to select DMA channel for ADC in Processor Expert?
2. How to add LPIT support for this DMA channel so that it can run independently?
3. What is the PDB configuration required for the above setting?
Thanks in Advance..!
Harish G
PetrS
harish_g2
Sorry for the late reply..!
Thank you..!
I will work on this and get back to you.
Regards..!
Harish G
PetrS
you can refer to below example,
https://community.nxp.com/docs/DOC-343295
BR, Petr
