i'm getting problem when i fill "0xDEADBEEF" in unused space in code section.
upendra_kumar
please help me when i try to fill code section with "0xDEADBEEF" and then by help of bootloader i flash the mcu then it's not working.
but without fill its working fine.
the fill code i have written in linker file.
 .fill :
FILL(0xDEADBEEF);
. = ORIGIN(m_text) + LENGTH(m_text) - 1;
BYTE(0xAA)
___ROM_AT = .;
} > m_text
jiri_kral
there is similar thread - hope it helps - https://community.nxp.com/thread/481926
Jiri
upendra_kumar
Thank you
Sharing information related linker file.
But my issue is first I debug without fill code section
Then after I debug with fill code section.
Then I compare both file I getting deferent data at 0x008150 address location.
Please find attach file
jiri_kral
well, it's hard to say with s-record only what can be wrong. It is possible share your project? When I run both versions - both ends in some loop around 0x3F0E address and never skips out from it.
Jiri
