GPIO config register
xu_ji1
Contributor V
Could u help detail explain about GPIO config below:
update_mux_mode
update lock for mux control
write 1 to allow programming to mux control [29:19]
update_pad_ctl
update lock for pad control
write 1 to allow programming to pad control [14-1:0]
Just for little words I can not understand it more,when set the register 1 and when set 0?
pls help it
Hi Xu
one can check sect.2.1.5.6 IOMUX Control Through GPIO Module attached Linux Manual and
sect.Chapter 8 Configuring IOMUX Porting Guide from nxp software documentation link below
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
For i.MX8 series use SCFW documentation in SCFW Porting Kit
