Here's how to program the flash with the MQX demo software. This is the web server demo that comes pre-flashed on the board and is described in the quick start guide. If you are having trouble with the board or would like to get it back in its original state follow these instructions.
Solved! Go to Solution.
I think you have an SRAM target selected. Typically the internal sram is mapped to addresses starting at 0x20000000. Be sure the select a Flash target, then launch the flash programmer.
MacL
When flashing same examples from the MQX, this message appears and he stop flashing.
in 0x00001C2C bytes of Target Memory at 0x20000420 is not within flash boundaries.
I need your help please.
Thinks
Enjoy technologies, enjoy life !!!
MacL
