Problem on running AN11782 LPC82x UART secondary bootloader
Question asked by nicky tsang on May 27, 2019
Latest reply on May 30, 2019 by Con Verse
I am following the application "AN11782 LPC82x UART secondary bootloader" to build the secondary bootloader to LPC824.
If you compile the bootloader example and debug using lpcxpresso, its working well.
Even i terminate, power off and on the device, it can still working.
However, the chip is not working if i load the hex file to the chip using flash magic.
Please see if anyone has met this case before and give advise
Nicky
