i.MX8 Multi-Camera EVS
xu_ji1
Contributor V
In auto-ga 2.1 release android user guide introduce Multi-Camera EVS function and have one sentence:
"This function is only available on the i.MX 8QuadMax MEK board. The i.MX 8QuadXPlus MEK board only supports one
camera."
I want to know what is diff with 8QM and 8QXP,why 8QXP only support one camera?
Hi Xu
in general i.MX8QXP can support two cameras, but MEK board seems only one
according to Fact Sheet
https://www.nxp.com/docs/en/fact-sheet/IMX8QADXPLUSFS.pdf
xu_ji1
Contributor V
hello,
The user guide said that i.MX8 android9  auto ga2.1 can support overall camera display,8QuadMax MEK board four camera show at same time,but 8QuadXPlus MEK only one.
I check the code about 8QM and 8QXP seems same,what is diff about them?
8QM has two MIPI-CSI modules
8QXP has one MIPI-CSI module + 1 parallel camera.
jack-cap
how to record four normal videos in imx8qm mek board on android os?
I test record four videos with mediarecorder on android, but I found that videos has skip frame. pls help to analysis. thanks a lot.
xu_ji1
Contributor V
we used MAX9286 connect 4 cameras with one MIPI-CSI,for this also only can use one camera?
seems auto-ga 2.1 8QXP release android supports only one, in general you can
add support for more camears yourself.
xu_ji1
Contributor V
How about auto-ga 2.1 8QM,is it support all four cameras?
one can look at Release Notes for supported features in
Android P9.0.0_2.1.0_Auto Documentation
xu_ji1
Contributor V
Yes,I check this documents,I want to know details about Multi-EVS function,how about the diff 8QM with 8QXP,in SW side or HW side or both?I have not found SW diff about 8QM and 8QXP myself.
all available documentation is provided on i.mx software web page
i.MX Software | NXP
xu_ji1
Contributor V
Seems all of the documents can not answer my question.
