problem jumping from bootloader to application
frank747
Hello, S32 team.
I had problems jumping from bootloader to application. My application will go into defaultISR.
I confirm that interrupts have been disabled before jumping to the application. I connected to the running MCU and found that sometimes I could execute in the application for a period of time, sometimes I couldn't. Jumping to defaultISR may occur in startup_xx.s or in main. Before entering defaultISR, I can debug the program step by step.
What may be the cause of this problem? My application works well without bootloader.
dianabatrlova
Do you use interrupts in the Application? If yes, did you relocate the vector table before the jump into the application by
S32_SCB->VTOR = (uint32_t)APP_START_ADDRESS; ?
I hope it helps.
Diana
