Good afternoon fellows of enineering, I've got the following problem which has been penetrating my nerves for hours and I really didn't make any progress.
The case: When I'm building my project on an Windows-XP OS in the 'CodeWarrior for DSC56800E v8.3' I get the following errors:
1) During the building process It tells me that an errors occured when moving file xxx.h from C/Users/Nick/AppData/Local/Temp..... to the actual location of the files. So the first directory doesn't even exist.
2) Also I get the error: 'Cant write application xxx.elf where in xxx on of the targets xyz_pROM_xRAM is involved-
I would be very thankful and send you an imaginary bar of chocolate if anybody would help me.
greetings Nick
HI,
Please send me your demo project. I need produce it and work on it directly. Thanks for your understanding.
Best Regards
Jun Zhang
