my touch device rebooting continuously i think it is in a boot loop could any one please help me
subramanikandas
Booting from root partition 1
Booting from app partition 1
Booting from kernel partition 1
=== Loading kernel and booting up ===
NAND read: device 0 offset 0x500000, size 0x800000
 8388608 bytes read: OK
=== Enabling WatchDog, 64sec timeout ===
=== Booting ===
## Booting kernel from Legacy Image at 70800000 ...
   Image Name:   Linux-2.6.35.3-0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2572068 Bytes =  2.5 MB
   Load Address: 70008000
   Entry Point:  70008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.35.3-0 (tsdop@precompiled-21.0.0-dbg-02a-KSP858-BR-container-build) (gcc version 5
4.0 (Buildroot 2016.08-00002-gbbebe28-dirty) ) #1 PREEMPT Fri Feb 15 17:57:26 UTC 2019
CPU: ARMv7 Processor [412fc085] revision 5 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: Freescale MX53 LOCO Board
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 121920
Kernel command line: console=ttymxc0,115200n8 consoleblank=0 video=mxcdi0fb:RGB24,KONE_1024_768 back
ight=15000,255,140,0 ubi.mtd=8 ubi.mtd=4 ubi.mtd=5 ubi.mtd=6 ubi.mtd=7 root=ubi1:root rootfstype=ubi
s up
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 480MB = 480MB total
Memory: 482396k/482396k available, 9124k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf8e00000 - 0xffe00000   ( 112 MB)
    vmalloc : 0x9e800000 - 0xf4000000   (1368 MB)
    lowmem  : 0x80000000 - 0x9e000000   ( 480 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .init : 0x80008000 - 0x80027000   ( 124 kB)
      .text : 0x80027000 - 0x8043c000   (4180 kB)
      .data : 0x80456000 - 0x80498f00   ( 268 kB)
SLUB: Genslabs=9, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
09 RCU-based detection of stalled CPUs is disabled.
09 Verbose stalled-CPUs detection is disabled.
NR_IRQS:368
MXC GPIO hardware
MXC IRQ initialized
MX5: PLL1 rate: 800000000
MX5: AEC 800MHz
MXC_Early serial console at MMIO 0x53fbc000 (options '115200n8')
bootconsole [ttymxc0] enabled
Calibrating delay loop... 532.48 BogoMIPS (lpj=2662400)
Mount-cache hash table entries: 512
devtmpfs: initialized
regulator: core version 0.5
i.MX IRAM pool: 128 KB@0x9e840000
IRAM READY
CPU is i.MX53 Revision 2.1
Using SDMA I.API
MXC DMA API initialized
IMX usb wakeup probe
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Advanced Linux Sound Architecture Driver Version 1.0.23.
mc34708 Rev 2.4 FinVer 0 detected
PMIC MC34708 ID:0x14
regulator: SW1: 650 <--> 1437 mV at 1250 mV
regulator: SW1B: 650 <--> 1437 mV at 1100 mV
regulator: SW2: 650 <--> 1437 mV at 1300 mV
regulator: SW3: 650 <--> 1425 mV at 1200 mV
regulator: SW4A: 1200 <--> 3300 mV at 1500 mV
regulator: SW4B: 1200 <--> 3300 mV at 1500 mV
regulator: SW5: 1200 <--> 1975 mV at 1800 mV
regulator: SWBST:
regulator: VPLL: 1200 <--> 1800 mV at 1800 mV
regulator: VREFDDR:
regulator: VDAC: 2500 <--> 2775 mV at 2775 mV
regulator: VUSB:
regulator: VUSB2: 2500 <--> 3000 mV at 2500 mV
regulator: VGEN1: 1200 <--> 1550 mV at 1300 mV
regulator: VGEN2: 2500 <--> 3300 mV at 2500 mV
pmic 0-0008: Loaded
Switching to clocksource mxc_timer1
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
LPMode driver module loaded
Static Power Management for Freescale i.MX5
PM driver module loaded
sdram autogating driver module loaded
Bus freq driver module loaded
DI0 is primary
mxc_dvfs_core_probe
DVFS driver module loaded
i.MXC CPU frequency driver
DVFS PER driver module loaded
JFFS2 version 2.2. (NAND) c2 a9  2001-2006 Red Hat, Inc.
msgmni has been set to 942
alg: No test for stdrng (krng)
cryptodev: driver loaded.
io scheduler noop registered
pwm-backlight pwm-backlight.0: PWM backlight frequency set to 15000Hz
pwm-backlight pwm-backlight.0: off duty cycle 255
pwm-backlight pwm-backlight.0: middle brightness duty cycle 140
pwm-backlight pwm-backlight.0: full brightness duty cycle 0
regulator: get() with no identifier
mxc_ldb mxc_ldb: default di0 single mode
IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
Serial: MXC Internal UART driver
mxcintuart.0: ttymxc0 at MMIO 0x53fbc000 (irq = 31) is a Freescale i.MX
console [ttymxc0] enabled, bootconsole disabled
mxcintuart.1: ttymxc1 at MMIO 0x53fc0000 (irq = 32) is a Freescale i.MX
mxcintuart.2: ttymxc2 at MMIO 0x5000c000 (irq = 33) is a Freescale i.MX
mxcintuart.3: ttymxc3 at MMIO 0x53ff0000 (irq = 13) is a Freescale i.MX
mxcintuart.4: ttymxc4 at MMIO 0x63f90000 (irq = 86) is a Freescale i.MX
loop: module loaded
at24 2-0050: 65536 byte 24c64 EEPROM (writable)
MXC MTD nand Driver 3.0
NAND device: Manufacturer ID: 0x01, Chip ID: 0xd3 (Spansion NAND 1GiB 3,3V 8-bit)
RedBoot partition parsing not available
Creating 9 MTD partitions on "NAND 1GiB 3,3V 8-bit":
0x000000000000-0x000000400000 : "bootloader"
0x000000400000-0x000000500000 : "bootscript"
0x000000500000-0x000000d00000 : "kernel1"
0x000000d00000-0x000001500000 : "kernel2"
0x000001500000-0x000014100000 : "root1"
0x000014100000-0x000026d00000 : "root2"
0x000026d00000-0x00002ad00000 : "app1"
0x00002ad00000-0x00002ed00000 : "app2"
0x00002ed00000-0x000040000000 : "data"
UBI: attaching mtd8 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    129024 bytes
UBI: smallest flash I/O unit:    2048
UBI: sub-page size:              512
UBI: VID header offset:          512 (aligned 512)
UBI: data offset:                2048
UBI: attached mtd8 to ubi0
UBI: MTD device name:            "data"
UBI: MTD device size:            275 MiB
UBI: number of good PEBs:        2196
UBI: number of bad PEBs:         4
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 2196
UBI: number of PEBs reserved for bad PEB handling: 21
UBI: max/mean erase counter: 13/5
UBI: image sequence number: 690230599
UBI: background thread "ubi_bgt0d" started, PID 1056
UBI: attaching mtd4 to ubi1
UBI: attached mtd4 to ubi1
UBI: MTD device name:            "root1"
UBI: MTD device size:            300 MiB
UBI: number of good PEBs:        2400
UBI: number of bad PEBs:         0
UBI: total number of reserved PEBs: 2400
UBI: number of PEBs reserved for bad PEB handling: 24
UBI: max/mean erase counter: 19/18
UBI: image sequence number: 1760829427
UBI: background thread "ubi_bgt1d" started, PID 1059
UBI: attaching mtd5 to ubi2
UBI: attached mtd5 to ubi2
UBI: MTD device name:            "root2"
UBI: max/mean erase counter: 18/17
UBI: image sequence number: 793385032
UBI: background thread "ubi_bgt2d" started, PID 1062
UBI: attaching mtd6 to ubi3
UBI: attached mtd6 to ubi3
UBI: MTD device name:            "app1"
UBI: MTD device size:            64 MiB
UBI: number of good PEBs:        512
UBI: total number of reserved PEBs: 512
UBI: number of PEBs reserved for bad PEB handling: 5
UBI: max/mean erase counter: 4/3
UBI: image sequence number: 631428060
UBI: background thread "ubi_bgt3d" started, PID 1065
UBI: attaching mtd7 to ubi4
UBI: attached mtd7 to ubi4
UBI: MTD device name:            "app2"
UBI: max/mean erase counter: 1/0
UBI: image sequence number: 519897797
UBI: background thread "ubi_bgt4d" started, PID 1068
FEC Ethernet Driver
fec_enet_mii_bus: probed
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 18, io base 0x53f80000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 14, io base 0x53f80200
usb 1-1: new high speed USB device using fsl-ehci and address 2
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
MXC keypad loaded
input: mxckpd as /devices/virtual/input/input0
scsi0 : usb-storage 1-1:1.0
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
atmel_mxt_ts 2-004a: Error -19 getting vdd regulator
atmel_mxt_ts 2-004a: Family: 164 Variant: 11 Firmware V1.2.AA Objects: 41
atmel_mxt_ts 2-004a: T100 Touchscreen size X1023Y767
atmel_mxt_ts 2-004a: Invalid object type T107
input: atmel_mxt_ts T100 touchscreen as /devices/platform/imx-i2c.2/i2c-2/2-004a/input/input1
i2c /dev entries driver
mxc_v4l2_output mxc_v4l2_output.0: Registered device video0
gspca: main v2.9.0 registered
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
Driver for 1-wire Dallas network protocol.
1-wire driver for the DS2438 smart battery monitor
MXC WatchDog Driver 2.0
MXC Watchdog # 0 Timer: initial timeout 60 sec
cpuidle: using governor ladder
cpuidle: using governor menu
PMIC ADC start probe
VPU initialized
mxc_asrc registered
gpu mmu enabled
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
No device for DAI imx-ssi-1-0
No device for DAI imx-ssi-1-1
No device for DAI imx-ssi-2-0
No device for DAI imx-ssi-2-1
DMA Sound Buffer Allocated: Playback UseIram=1 ext_ram=0 buf->addr=f8016000 buf->area=9e856000 size=
4576
asoc: tlv320dac3100 <-> imx-ssi-2-0 mapping ok
Control name 'Beep generator Volume Control(0 = -61 dbdB, 63 = 2 dB)' truncated to 'Beep generator V
lume Control(0 = -61 dbdB,'
Control name 'SP Class - D driver Volume(0 = 6 dB, 4 = 24 dB)' truncated to 'SP Class - D driver Vol
me(0 = 6 dB, 4 = 24'
Control name 'HP Analog Gain Volume(0 = 0 dB, 127 = -78.3 dB)' truncated to 'HP Analog Gain Volume(0
= 0 dB, 127 = -78.3'
Control name 'SP Analog Gain Volume(0 = 0 dB, 127 = -78.3 dB)' truncated to 'SP Analog Gain Volume(0
Control name 'Right Output Mixer DAC_R To Right Mixer Amp switch' truncated to 'Right Output Mixer D
C_R To Right Mixer Amp'
Control name 'Right Output Mixer DAC_R To HPR Driver switch' truncated to 'Right Output Mixer DAC_R
o HPR Driver swit'
Control name 'Left Output Mixer DAC_L To Left Mixer Amp switch' truncated to 'Left Output Mixer DAC_
 To Left Mixer Amp s'
Control name 'Left Output Mixer DAC_L To HPL Driver switch' truncated to 'Left Output Mixer DAC_L To
HPL Driver switc'
ALSA device list:
  #0: imx-3stack (TLV320DAC3100)
TCP cubic registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 1, volume 0, name "root"
UBIFS: file system size:   304496640 bytes (297360 KiB, 290 MiB, 2360 LEBs)
UBIFS: journal size:       15224832 bytes (14868 KiB, 14 MiB, 118 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  4952683 bytes (4836 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
devtmpfs: mounted
Freeing init memory: 124K
init: upstart-dbus-bridge main process (1178) terminated with status 1
init: upstart-dbus-bridge main process ended, respawning
Starting logging: OK
scsi 0:0:0:0: Direct-Access     JetFlash Transcend 4GB    8.07 PQ: 0 ANSI: 4
sd 0:0:0:0: [sda] 7864320 512-byte logical blocks: (4.02 GB/3.75 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
Populating /dev using udev: sd 0:0:0:0: [sda] Assuming drive cache: write through
 sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
UBIFS: mounted UBI device 0, volume 0, name "data"
UBIFS: file system size:   278562816 bytes (272034 KiB, 265 MiB, 2159 LEBs)
UBIFS: journal size:       13934592 bytes (13608 KiB, 13 MiB, 108 LEBs)
<30>udevd[1197]: starting version 3.2.5
<27>udevd[1197]: NAME="%k" is ignored, because it breaks kernel supplied names, please remove it fro
 /etc/udev/rules.d/usb.rules:1
<30>udevd[1204]: starting eudev-3.2.5
Checking partition consistency
done
Initializing random number generator... done.
Starting system message bus: done
Starting rpcbind: OK
Starting network: eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
udhcpc: started, v1.27.2
udhcpc: sending discover
PHY: 0:00 - Link is Up - 100/Full
udhcpc: sending select for 192.168.80.1
udhcpc: lease of 192.168.80.1 obtained, lease time 1601
/usr/share/udhcpc/default.script: Adding NTP server 192.168.66.11
restart: Unknown instance:
OK
Starting nginx...
Starting sshd: OK
i don't know what is the problem here i'm using MCIMX537CVV8C  the Touch scree is rebooting continuously. Could any one please help
Tags (2)
Hi Subramani
for i.MX53 touchscreen one can look at below threads
and use Mfg Tool for reflashing image
MX53 MC34708 touchscreen
https://community.nxp.com/docs/DOC-1302
i.MX Manufacturing Toolkit
