Is there a document including registers map of S32K148?
I found the data sheet, https://www.nxp.com/docs/en/data-sheet/S32K-DS.pdf . But, it doesn't have register map.
Solved! Go to Solution.
I'm afraid that there is no such document (registers map). In reference manual you can find memory map - https://www.nxp.com/docs/en/reference-manual/S32K-RM.pdf
All registers are described in modules (UART, GPIO...).
Jiri
Jiri
that link goes to "Page not found". Is that document still somewhere available? I can't find it.
Hi Jiri
This is what I want to have. Thanks!
Hideki
