SC16IS740
SC16IS740
masonnoh
Is it support to baud rate a 115,200?
Datasheet show 5,600(max) using a 1.8432 MHz crystal.
guoweisun
HI
You can get more information in datasheet page18-7.8 Programmable baud rate generator for calculation of baud rate under different condition.
masonnoh
I already got that information in datasheet. I just would like to know allowable baud rate values.
You mean 115,200 is allowable?
guoweisun
So you mean fixed 1.8432 MHz crystal to get the 115,200 baud rate values,right?
guoweisun
You can get maximum is 115200 when fixed 1.8432MHz when setting the divisor is 1.
masonnoh
Yes, that's exactly what I want to know.
