We are currently trying to change the eth2 pins to i2c pins but we cannot get ethernet working when we disable eth2 (fec2). I have tried moving the mdio node to the fec1 node, but I still can't get it to work. Any suggestions? Also, what does the @1 in ethernet-phy@1 mean?
I have the following in my device.dts
Hi Glenn
one can look at example on
imx6ul-liteboard.dts\dts\boot\arm\arch - linux-imx - i.MX Linux kernel
fsl-fec.txt\net\bindings\devicetree\Documentation - linux-imx - i.MX Linux kernel
http://wiki.litesom.grinn-global.com/images/1/1d/LiteSOM_training.pdf
