Hola, necesito informacion para aprender a programar un kit de desarrollo TWR-K40x256 ARM Cortex M-4 en codewarrior, podrian recomendarme algun manual de programacion o algun material similar ?
Hi Sebastian Gonzalez ,
Next time, please create your question in English.
This time, I use the translation tool to translate your question:
Hello, I need information to learn how to program a development kit TWR-K40x256 ARM Cortex M-4 in codewarrior, could you recommend me some programming manual or some similar material?
Answer your question:
Actually, TWR-K40x256 is really a little old now.
But if you want to use it, you can refer to the document in this link:
TWR-K40X256|Tower System Board|Kinetis MCUs | NXP
About the code, I attach the KINETIS512_SC.zip, it already have the CW project for your board.
The board already have the on board debugger, you can use it directly.
Wish it helps you!
Kerry
