maniram nagothi
Re: Failed on connect: Ee(42). Could not connect to core. No connection to chip's debug port
Discussion created by maniram nagothi on May 15, 2019
Latest reply on May 16, 2019 by jeremyzhou
Branched from an earlier discussion
Hi jeremyzhou,
thank you for sharing the data, the PDF link you have shared uses the IAR IDE,can u please share the steps or any PDF document which uses MCUxpresso IDE options.
Maniram
