PN7462 Antenna matching circuit
sanath_rai
We are using PNEV7462C  development kit.
which has 65x65 antenna we are looking for the antenna size to 15x25mm(ANFCA-2515-A02).
Can any one suggest the matching circuit for the above mentioned antenna and we have tried refernece matching circuit values mentioned in the datasheet as attached below and also see the current antenna component placement as attached below.antenna design and placement.png
Sanath Rai
Kan_Li
The antenna tuning needs calculation with measurement on your custom antenna, you can not directly apply the matching circuits from the ref design to your custom board. Please refer to the following link for details.
NFC Antenna Design
Kan
Kan_Li
NFC Antenna Design
Kan
sanath_rai
Hello Kan_Li,
As we have missed the 30x50 Antenna board which came along with the development board (PNEV7462C) we would like to know the matching circuit values.
Sanath
sanath_rai
Hi Kan_Li,
Thank you for the reply we will work on it.
Sanath Rai
