Question about update install failure S32DS_ARM_v2018.R1_UP*.zip
jm_shin
Hello
I updated the S32DS along the guide page. (HOWTO: Update S32 Design Studio )
However, Problems will occur when installing S32DS_ARM_v2018.R1_UP*.zip.(update 1,8,9,10)
Whenever i perform an update, the 'freescale semiconductor' message appears.
If i select ok, an error will occur in S32DS.
If i select cancel, it can not update.
Problem Scenario
1) offline installation
Help" -> "Install New Software..." -> S32DS_ARM_v2018.R1_UP10
2) install start
3) 'freescale semiconductor' message appears.
4) If it select cancel
If there is a solution, please share it.
Tags (2)
jiri_kral
I tried the same scenario - and for me is offline update working okay. You can try fresh install of S32DS and then apply update 10.
Jiri
jiri_kral
Jiri
jm_shin
Dear Jiri Kral
Thank you for answer.
