LPC54018JxM : flashing internal flash
Question asked by bob belmont on May 14, 2019
Latest reply on Nov 29, 2019 by S.z. Liang
Do you have some sample project to flash LPC54018JxM’s internal flash?
I’ve downloaded full 54S018M::SDK 2.5.0 but could not find any example.
While browsing SDK builder’s standalone examples for 54S018M; I stumbled upon and downloaded “flashloader” (targeting KEIL IDE); however there is no readme file and the project does not compile, I get the errors below. Please advise.
*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Rebuild target 'flashloader release'
compiling external_memory_property_map_LPC54S018M.c...
LPC54S018M/external_memory_property_map_LPC54S018M.c(8): error:  #5: cannot open source input file "property/property.h": No such file or directory
  #include "property/property.h"
LPC54S018M/external_memory_property_map_LPC54S018M.c: 0 warnings, 1 error
compiling bl_flexcomm_spi_irq_config_common.c...
LPC54S018M/bl_flexcomm_spi_irq_config_common.c(8): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
  #include "bootloader/bl_context.h"
LPC54S018M/bl_flexcomm_spi_irq_config_common.c: 0 warnings, 1 error
compiling bl_flexcomm_usart_irq_config_common.c...
LPC54S018M/bl_flexcomm_usart_irq_config_common.c(8): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/bl_flexcomm_usart_irq_config_common.c: 0 warnings, 1 error
compiling bl_flexcomm_i2c_irq_config_common.c...
LPC54S018M/bl_flexcomm_i2c_irq_config_common.c(8): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/bl_flexcomm_i2c_irq_config_common.c: 0 warnings, 1 error
compiling memory_map_LPC54S018M.c...
LPC54S018M/memory_map_LPC54S018M.c(8): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/memory_map_LPC54S018M.c: 0 warnings, 1 error
compiling peripherals_LPC54S018M.c...
LPC54S018M/peripherals_LPC54S018M.c(8): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/peripherals_LPC54S018M.c: 0 warnings, 1 error
compiling key_store_hal_lpc54s018.c...
source/authentication/src/key_store_hal_lpc54s018.c(8): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/authentication/src/key_store_hal_lpc54s018.c: 0 warnings, 1 error
compiling bl_app_crc_check.c...
source/bootloader/src/bl_app_crc_check.c(8): error:  #5: cannot open source input file "utilities/fsl_assert.h": No such file or directory
  #include "utilities/fsl_assert.h"
source/bootloader/src/bl_app_crc_check.c: 0 warnings, 1 error
compiling bl_context.c...
source/bootloader/src/bl_context.c(9): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/bootloader/src/bl_context.c: 0 warnings, 1 error
compiling autobaud_irq.c...
source/autobaud/autobaud_irq.c(9): error:  #5: cannot open source input file "autobaud/autobaud.h": No such file or directory
  #include "autobaud/autobaud.h"
source/autobaud/autobaud_irq.c: 0 warnings, 1 error
compiling bl_main.c...
source/bootloader/src/bl_main.c(11): error:  #5: cannot open source input file "utilities/fsl_assert.h": No such file or directory
source/bootloader/src/bl_main.c: 0 warnings, 1 error
compiling clock_config_LPC54S018M.c...
LPC54S018M/clock_config_LPC54S018M.c(9): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/clock_config_LPC54S018M.c: 0 warnings, 1 error
compiling hardware_init_LPC54S018M.c...
LPC54S018M/hardware_init_LPC54S018M.c(9): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/hardware_init_LPC54S018M.c: 0 warnings, 1 error
compiling bl_command.c...
source/bootloader/src/bl_command.c(10): error:  #5: cannot open source input file "bootloader/bootloader.h": No such file or directory
  #include "bootloader/bootloader.h"
source/bootloader/src/bl_command.c: 0 warnings, 1 error
compiling pinmux_utility_lpc.c...
LPC54S018M/pinmux_utility_lpc.c(12): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
LPC54S018M/pinmux_utility_lpc.c: 0 warnings, 1 error
compiling bl_misc.c...
source/bootloader/src/bl_misc.c(8): error:  #5: cannot open source input file "bootloader/bootloader.h": No such file or directory
source/bootloader/src/bl_misc.c: 0 warnings, 1 error
compiling system_LPC54S018M.c...
compiling fsl_power.c...
compiling fsl_reset.c...
compiling fsl_common.c...
compiling fsl_inputmux.c...
compiling bl_shutdown_cleanup.c...
source/bootloader/src/bl_shutdown_cleanup.c(10): error:  #5: cannot open source input file "utilities/fsl_rtos_abstraction.h": No such file or directory
  #include "utilities/fsl_rtos_abstraction.h"
source/bootloader/src/bl_shutdown_cleanup.c: 0 warnings, 1 error
compiling bl_tree_root.c...
source/bootloader/src/bl_tree_root.c(9): error:  #5: cannot open source input file "bootloader/bootloader.h": No such file or directory
source/bootloader/src/bl_tree_root.c: 0 warnings, 1 error
compiling fsl_crc.c...
compiling key_store.c...
compiling flexcomm_i2c_peripheral_interface.c...
source/bootloader/src/flexcomm_i2c_peripheral_interface.c(10): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/bootloader/src/flexcomm_i2c_peripheral_interface.c: 0 warnings, 1 error
compiling bl_exception_handler.c...
compiling fsl_flexcomm.c...
compiling fsl_power_lib.c...
compiling fsl_puf.c...
compiling flexcomm_spi_peripheral_interface.c...
source/bootloader/src/flexcomm_spi_peripheral_interface.c(9): error:  #5: cannot open source input file "utilities/fsl_assert.h": No such file or directory
source/bootloader/src/flexcomm_spi_peripheral_interface.c: 0 warnings, 1 error
compiling fsl_usart.c...
compiling flexcomm_usart_peripheral_interface.c...
source/bootloader/src/flexcomm_usart_peripheral_interface.c(9): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/bootloader/src/flexcomm_usart_peripheral_interface.c: 0 warnings, 1 error
compiling usb_osa_bm.c...
compiling usb_hid_msc_peripheral_interface.c...
source/bootloader/src/usb_hid_msc_peripheral_interface.c(9): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/bootloader/src/usb_hid_msc_peripheral_interface.c: 0 warnings, 1 error
compiling crc32.c...
source/crc/crc32.c(8): error:  #5: cannot open source input file "crc/crc32.h": No such file or directory
  #include "crc/crc32.h"
source/crc/crc32.c: 0 warnings, 1 error
compiling crc16.c...
source/crc/crc16.c(8): error:  #5: cannot open source input file "crc/crc16.h": No such file or directory
  #include "crc/crc16.h"
source/crc/crc16.c: 0 warnings, 1 error
compiling bl_user_entry.c...
compiling fsl_spi.c...
compiling fsl_i2c.c...
compiling normal_memory.c...
source/memory/src/normal_memory.h(10): error:  #5: cannot open source input file "memory/memory.h": No such file or directory
  #include "memory/memory.h"
source/memory/src/normal_memory.c: 0 warnings, 1 error
compiling device_memory.c...
source/memory/src/device_memory.h(10): error:  #5: cannot open source input file "memory/memory.h": No such file or directory
source/memory/src/device_memory.c: 0 warnings, 1 error
compiling aes_otp.c...
compiling fsl_gpio.c...
compiling sram_init_lpc.c...
source/memory/src/sram_init_lpc.c(9): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/memory/src/sram_init_lpc.c: 0 warnings, 1 error
compiling fsl_gint.c...
compiling fsl_clock.c...
assembling pattern_fill.s...
compiling microseconds_sysclk.c...
source/drivers/microseconds/microseconds_sysclk.c(150): error:  #20: identifier "__WEAK" is undefined
  __WEAK uint32_t microseconds_get_clock(void)
source/drivers/microseconds/microseconds_sysclk.c(150): error:  #101: "uint32_t" has already been declared in the current scope
source/drivers/microseconds/microseconds_sysclk.c(150): error:  #65: expected a ";"
source/drivers/microseconds/microseconds_sysclk.c(164): warning: At end of source:  #12-D: parsing restarts here after previous syntax error
source/drivers/microseconds/microseconds_sysclk.c: 1 warning, 3 errors
compiling serial_packet.c...
source/packet/src/serial_packet.c(10): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/packet/src/serial_packet.c: 0 warnings, 1 error
compiling sbloader.c...
source/sbloader/src/sbloader.c(12): error:  #5: cannot open source input file "sbloader/sbloader.h": No such file or directory
  #include "sbloader/sbloader.h"
source/sbloader/src/sbloader.c: 0 warnings, 1 error
compiling spifi_nor_memory.c...
source/memory/src/spifi_nor_memory.c(9): error:  #5: cannot open source input file "bootloader/bootloader.h": No such file or directory
source/memory/src/spifi_nor_memory.c: 0 warnings, 1 error
compiling property_lpc.c...
source/property/src/property_lpc.c(10): error:  #5: cannot open source input file "property/property.h": No such file or directory
source/property/src/property_lpc.c: 0 warnings, 1 error
compiling memory.c...
source/memory/src/memory.c(10): error:  #5: cannot open source input file "bootloader/bl_context.h": No such file or directory
source/memory/src/memory.c: 0 warnings, 1 error
compiling fsl_assert.c...
source/utilities/src/fsl_assert.c(8): error:  #5: cannot open source input file "utilities/fsl_rtos_abstraction.h": No such file or directory
source/utilities/src/fsl_assert.c: 0 warnings, 1 error
compiling fsl_rtos_abstraction.c...
source/utilities/src/fsl_rtos_abstraction.c(8): error:  #5: cannot open source input file "utilities/fsl_assert.h": No such file or directory
source/utilities/src/fsl_rtos_abstraction.c: 0 warnings, 1 error
compiling fsl_spifi.c...
compiling otp.c...
assembling startup_LPC54S018M.s...
compiling fsl_pint.c...
compiling startup.c...
compiling hid_bootloader.c...
source/usb/bm_composite/hid_bootloader.h(13): error:  #5: cannot open source input file "utilities/fsl_rtos_abstraction.h": No such file or directory
source/usb/bm_composite/hid_bootloader.c: 0 warnings, 1 error
compiling msc_disk.c...
source/usb/bm_composite/msc_disk.c(18): error:  #5: cannot open source input file "sbloader/sbloader.h": No such file or directory
source/usb/bm_composite/msc_disk.c: 0 warnings, 1 error
compiling composite.c...
source/usb/bm_composite/composite.c: 0 warnings, 1 error
compiling usb_descriptor.c...
source/usb/bm_composite/bootloader_hid_report_ids.h(10): error:  #5: cannot open source input file "packet/command_packet.h": No such file or directory
  #include "packet/command_packet.h"
source/usb/bm_composite/usb_descriptor.c: 0 warnings, 1 error
compiling spifi_nor_flash.c...
compiling usb_device_msc_ufi.c...
compiling usb_device_msc.c...
compiling usb_device_hid.c...
compiling usb_device_class.c...
compiling usb_device_ch9.c...
compiling usb_device_dci.c...
compiling usb_device_lpcip3511.c...
"release\flashloader.out" - 41 Error(s), 1 Warning(s).
Target not created.
Build Time Elapsed:  00:00:05
