PN7462 flash programming,power reset
Question asked by sanath rai on May 14, 2019
Latest reply on Aug 26, 2019 by Sachin Singh
I am working on pn7462 development kit, nfc based application.
I have downloaded pn7462 firmware from the nxp site and have dumped the example codes.
I am using lpclink to debug the board.but I am not able to flash the code into pn7462 ,that is after power on reset I need to dump the code again to run the application.how to make it run from the flash so that even after power reset application should start running .
Thank you
Sanath Rai
