IMX8M kernel 4.14.78 and Xilinx Slave Serial SPI FPGA Manager
fredericduchass
I try to pogram my Xilinx FPGA after boot.
I've followed the indication in this link concernening my devicetree :
linux/xilinx-slave-serial.txt at master · torvalds/linux · GitHub
But i don't know how to give my bitfile ?How I can program an fpga region ?
There is not a lot of help concerning this topic...
Frédéric
diegoadrian
Unfortunately, this problem is more related to how you program your FPGA, here is not a lot of what we could help you.
Seeing the link that you posted, I could see that you only configured the dtb to use the SPI interface. But, to program the FPGA you could use an SPI Flash, or simulate the J-tag protocol through SPI.
Please find more information about how to program the FPGA through an SPI Flash.
https://www.xilinx.com/support/documentation/application_notes/xapp1188-config-spi.pdf
Unfortunately, we are unable to assist you more, since this problem is out of our scope. I recommend you to go with Xilinx, they could help you with your problem.
Diego.
fredericduchass
Hi Diego,
I don't want to program my fpga using serial flask or jtag.
I want to program my fpga using a method called "Xilinx Slave Serial SPI FPGA Manager".
This FPGA programmation framwork is included in the kernel used.
so i carefully read this link :
That's why I create in my dtb, a spi fpga manager + an fpga region. So the programmation method (SPI) is already selected in device tree.
And now i really don't know how to program this fpga region.... there is a lack of documentation about that.
