facing issue with ethernet in custom board developed with p2020rdb ,
In this board we populate section wise .we have two ethernets 'etsec3' & 'etsec1' ,first we populate etsec3 communication established ,
after that i tried to populate the 'etsec1' then it is succesfully communication established, and etsec3 not working .
whats the problem??
Thank you in advance!!!!!!
Please check, both ports are use the same phy or different phy.
VinothS
Using different phy
