Question 1 : When collecting HV current with MM9Z1_638, does the GND of the module need to be connected with ISENSEL?
Question 2: In the BCI experiment, refer to the iso11452-4 standard, the current sampling data fluctuates greatly, and what factors will affect it?
Solved! Go to Solution.
The MM9Z1_638 is measuring the ISENSE using GND referenced Inputs. The table below (from the datasheet) indicates the limitations / requirements for proper operation:
VINC is the voltage from ISENSEH to Gnd and from ISENSEL to Gnd
VIND is the differential voltage between ISENSEH and ISENSEL
Typically the IC/module GND point should be on the Shunt resistor either the "ISENSEH-side" or "ISENSEL-side".
ISENSEL side referenced to GND | ISENSEH side referenced to GND | |
Current measurement (ISENSE) | I load + I sup | I load |
Voltage measurement (e.g. VSENSE2) | V bat + V drop | V bat |
Its difficult to give an exhausted answer. In general layout and Grounding has to be carefully handled. In particular avoiding any unwanted currents on the sense lines (ISENSEH/ISENSEL). Maybe you could provide more details? You can send my a direct message by clicking on my name.
