IMX RT1050 EVK read data error with 60℃ temperature.
dingzhongkui
Hello:
It  is   a  urgent   problem  .     IMX RT1050  EVK   read  data  error  with  60℃ temperature.  The error reason is about sdram,because the test software  is    i.mxrt-dram-tool-v0.2 .   Errors are not fixed,sdram  has not  return  data  or  someone  data  is wrong.      IC  is  ISSI   IS42S16160J-6BLI.
dingzhongkui
How many IMXRT1050-EVK board with this high temperature working issue?
ANS:  I don't kown the precise number,The only one EVK has been use for  me.
I couldn't find there with any same record about IMXRT1050-EVK board.
Do you also test with IMXRT1050-EVKB board?
ANS:Yes.  FAE help me.
What's the test result?
ANS:As follows。
Mike
Hui_Ma
Thank you for the info.
Please correct me that the posted test result pictures only related with IMXRT1050-EVK board, not IMXRT1050-EVKB board.
Is my understanding right?
Mike
Hui_Ma
Mike
