I have received the materials you sent to me. But I can't tell which type of pressure sensor is described above. What I need to know is the ability of MPX53 pressure sensor to resist interference under rf magnetic field radiation. I would like to ask if you have any test on this aspect or any other customers have encountered this kind of situation? When doing iec 61000-4-3:2010 test. The pressure increases rapidly.
