Solved! Go to Solution.
Just in case anyone ends up here, I thought I'd post a resolution...
I finally added this flag to my PIT initialization:
MCF_PIT_PCSR_DBG
And now the debugger doesn't just step into the timer isr on the M52259DEMOKIT.
I'm not sure why I would ever want any other behavior.
-- Rich
MCF_PIT_PCSR_DBG
-- Rich
Working with
OSBDM
OSBDM = Open Source
Background Debug Mode
Ensure your CodeWarrior projects are
setup correctly for the on board OSBDM
debugger circuit. Type Alt+F7 to open
the Project Settings window. Click
Remote Debugging and select ColdFire
v2-v4 JM60 OSBDM. If this option is not
available, check that CodeWarrior 7.1 is
installed correctly.
