I am doing gstreamer pipeline on the imxm mini board, software version is 4.14.78-imx_4.14.78_1.0.0_ga+g94da7bd imx8mmevk.
I found waylandsink is not supported on the imx8m mini. Below is my test:
root@imx8mmevk:/unit_tests/Audio#
root@imx8mmevk:/unit_tests/Audio# gst-launch-1.0 filesrc location=720p.mp4 ! qtdemux ! queue ! h264parse ! vpudec ! waylandsink
Setting pipeline to PAUSED ...
====== VPUDEC: 4.4.4 build on May 6 2019 06:48:28. ======
wrapper: 3.0.0 (VPUWRAPPER_ARM64_LINUX Build on Apr 24 2019 05:16:41)
vpulib: 1.1.1
firmware: 1.1.1.0
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:14.973788500
Setting pipeline to READY ...
Setting pipeline to NULL ...
Total showed frames (302), playing for (0:00:14.974217875), fps (20.168).
Freeing pipeline ...
This gstreamer pipeline above will make screen green and does not have any video display.
Could you help me fix this bug? Thanks.
how about changing the waylandsink to kmssink or glimagesink ? what backend do you build for your image?
