LCD_DATAx RGB mapping for i.MX6SL
ko-hey
Senior Contributor II
Hi all,
In my customer board which is iMX6SL based with 18-bit is required.
But I can not find the description of mapping of LCD_D[0..17] to RGB components in RM. Help is need, thanks in advance.
Ko-hey
Rita_Wang
Hi Ko-key,
About the 8bit/16bit/18bit/24bit use you can see the detail use in 20.4.12 LCDIF Pin Usage by Interface Mode in the i.MX6SL RM.
Take the the 18bit RGB666 as an example:
(1) RED
LCD_DATA12~LCD_DATA17
(2) GREEN
LCD_DATA06~LCD_DATA11
(3) BLUE
LCD_DATA00~LCD_DATA05
Rita
ko-hey
Could someone answer and follow this question ?
Ko-hey
Rita_Wang
Hi Ko-key,
(1) RED
(2) GREEN
(3) BLUE
Rita
ko-hey
Hi b45499
Let me confirm the connection again.
Are the following connections correct ?
LCD_DATA00~LCD_DATA05B0B5
LCD_DATA06~LCD_DATA11G0G5
LCD_DATA12~LCD_DATA17R0R5
Ko-hey
Rita_Wang
Hi Ko-hey,
Can you send you LCD screen datasheet or LCD interface information to us? The connection also depend on the screen you are using.
Rita
ko-hey
Hi Rita Wang
I made a Case 00221192 because it is confidential infromation.
Could you check the case ?
Ko-hey
Rita_Wang
Hi Ko-hey,
I have confirmed it for you that your connection is right.
Have a nice day
Rita
Rita_Wang
Hi Ko-key,
I am confirming it for you, and then give you reply as soon as possible.
Have a nice day
Rita
