acelerometro MMA7660FC
jortega27
Hola buen dia:
tengo una pregunta quisiera saber como se leen los registros del acelerometro, osea los datos de cada uno de los ejes x,y,z,   para una demoqe128. Se que se comunica con la interfaz IIC, pero no la verdad e buscado como poder leer los datos especificamente que envie uno de los ejes muchas gracias.
reyes
Hi Juan Pablo,
Thank you for contacting NXP.
Since our support engineers are located worldwide, for future reference I recommend you enter your question in English. This is also why I’m answering in English.
Register list and its definitions can be found from page 14 to 21 of the datasheet: https://www.nxp.com/docs/en/data-sheet/MMA7660FC.pdf
Please find an attached an example code for read and filter that you can use as a reference for your MMA7660 code.
