i.MX6UL Development board with PSDRAM attached to EIM
j_araya
Dear Community,
Is there any development board you can recommend, either from NXP or any third-party company with a PSDRAM or FPGA attached to the EIM port of the i.MX6 processor?
Kind regards,
Jose
Rita_Wang
You can realize the EIM connect to the FPGA yourself. You can see the RM
j_araya
Hi Rita,
Thanks for your answer. The EIM port multiplexing described in the tables you mention can actually be quickly done with the PINS-TOOL-IMX, right?
I wanted to avoid the overhead of designing a PCB just to try the PSRAM interface of the EIM port, but if there is no other option I'll need to proceed as you suggest.
Bests,
Jose
