Does anyone know what COINIT bit in QTMR CTRL register for? And how to use it?
Solved! Go to Solution.
Hi Jei Chou,
for the opportunity to serve you.
After enabling the COINIT bit, the compare event happens can reinitialize all four counter/timer in a timer module instead of only one counter/timer before.
Hope this is clear.
TIC
Hi Jei Chou,
Hope this is clear.
TIC
