clFFT for GPU on i.MX 8M board
golchin2010p
I would to use clFFT for GPU core of my board (phyBOARD-Polaris i.MX 8M). I have followed the instruction of this link https://github.com/clMathLibraries/clFFT.  For kernel size of 128, it takes more than a second to do the computations. Is there a way to reduce the kernel computation for larger kernel sizes?
I would greatly appreciate your help.
Parian
Tags (2)
CarlosCasillas
Hi Parian,
As the mentioned board is from Pythec, you should directly contact them for hardware/software questions:
Support | PHYTEC
In case if requiring a custom software integration, you may consider NXP Professional Services:
NXP Professional Services | NXP
Hope this will be useful for you.
Best regards!
/Carlos
