I am working on i.mxrt1064 USB. I am trying to connect one CDC device to processor host. Device is getting attached and enumeration is also done. But sometimes in USB_HostEhciTransactionDone API it is leading to transfer failed.
I am not able to find the issue, Please help.
Thanks and Regards,
Ravi Ranjan Kumar.
Hello Ravi Ranjan Kumar,
Are you using our evaluation board or your own? Are you using the drivers we provide within the SDK? Are you using an example from the SDK or your own project?
TIC
