glimagesink displays wrong colors and has low framerate
anthony3
I'm having trouble using glimagesink, which I currently need for gltransformation.
When I run
gst-launch-1.0 autovideosrc ! glimagesink
I get the message "There may be a timestamping problem, or this computer is too slow."
The image looks like this : IMG_20190430_182545.jpg
However, I got the correct colors and 30fps when I use
gst-launch-1.0 autovideosink ! fpsdisplaysink
currently both of the images above are 1920x1080, however I will be cropping them to a square image in the future.
Does anyone know how to
  • Correct the image color when using glimagesink
  • improve framerate when using glimagesink
Thank you,
Labels (2)
Bio_TICFSL
Hello Anthony,
Which BSP are you using? which board?
