Reboot command is not working properly in linux4.14
santoshrao
Hi all,
      Software reboot command is not working properly when I give the $ sudo reboot and It stopped after all processes shutdown. If any one knows help me out.
Santosh
Hi Santosh
one can check that power was removed all components on the board in the event of a
processor reset, as it is done in i.MX8M EVK design (with nWDOG U704 (UM805RE))
https://www.nxp.com/support/developer-resources/evaluation-and-development-boards/sabre-development-...
Otherwise one can try to debug and analyse which component remains in non-reset state, probably
dumping processor modules registers in good and non-working case.
santoshrao
Hi igor,
         I think it is not an issue with watchdog module and after stopped all services again its not restarting in linux4.14 only.If you take linux4.19 its working properly.
Santosh
Hi Santosh
if above requirement is not satisfied issue is random
and may vary depending on used kernel and board.
santoshrao
Hi igor,
       1. Can you explain how reboot works and reboot working flow.
       2. Reboot command will works without watchdog timer in any arm device
Santosh
Hi Santosh
could you try to reproduce issue on nxp reference board with
nxp official linux from source.codeaurora.org/external/imx/linux-imx repository
linux-imx - i.MX Linux kernel
