i.mx6ul 支持ARGB?
i.mx6ul 支持ARGB?
haifeng_jin
hi  I.MX6UL支持ARGB吗,有没有相关的示例可以在demo板上测试?
joanxie
what do you mean? for capturing, decoding or decoding? pls give me more detailed information about this
haifeng_jin
用于LCD显示,直接QT去做图形显示
joanxie
refer to the yocto 4.9.88 release note:
For i.MX 6UltraLite, i.MX 6ULL and i.MX 7Dual SABRE-SD, it supports Embest
LCD8000-43T LCD panel.
so you can use this lcd panel directly
haifeng_jin
在这个屏幕上能不能出透明的效果?ARGB的功能?
joanxie
imx6ul PXP supports this, for more detailed information, pls refer to the 39.3.12 Alpha Blending/Color Key, 39.3.13 Alpha Blend and 39.3.14 Color Key of imx6ul reference manual
